You understod my questions right I got two lines with 16 pins and only one line is connected to something the other line is useless but I need the holes for it.
So I can name the fiirst 16 pins ans the 16 others we don’t care right ?
That is correct, you can just leave the default name that Inkscape gives them or you could give them a name like pin1, hole3, circle_5. You can do the same thing with pads…
Alright thank you I renamed them as if I would have connections so if I need to change and add some it’s already done .
I finally get through this design part, thank for your help everyone and maybe I can share it so someone can modify as he want ?
Set out a grid with 2.54 by 5mm and snap contacts/circles to the centres. Put them in a group called copper0, and then put that in a group called copper1. copper0 is the bottom layer, and because it’s in copper1 it duplicates it on the top layer. Next make a rectangle, I would ignore the toggles and make it 12.1mm by the length for the number of pins you want, and then put that in a group called silkscreen.
