GT U8 Module GPS
GT-U8 GPS Module
Previous work, similar parts
There are no known existing Fritzing parts for the GT-U8 GPS Module.
Please refer to the image below for the top view of the module, showing the layout of connectors and dimensions:
https://www.amazon.ca/Control-Satellite-Positioning-Navigator-atgm336h/dp/B0B6JDBQF6
Not Found
Breakout board, subassembly, plug-in module (A)
Other (please specify): GPS Module
  • Module Dimensions: 15.7 x 13.1 x 4mm
  • Pin Spacing: Standard 2.54 mm pitch
  • Header Pins: VCC, GND, TXD, RXD, PPS
Additional Notes
The GT-U8 is a compact GPS module that supports multiple global navigation systems, including GPS, GLONASS, GALILEO, QZSS, and BDS. This part should include:
  • Standard pin headers for VCC, GND, TXD, RXD, and PPS.
  • The part should have a rectangular outline representing the module’s dimensions.
  • The part’s description should include operational voltage (3.3V) and any other relevant information.
GT-U8-GPS-module.fzpz (4.2 KB)
thank you very much!
