Fritzing PART CREATION Video Tutorial Series
Making Fritzing Parts Fast 3 - Schematic
0:00 Intro
1:01 Setup Inkscape
1:31 Drawing the schematic from scratch
3:08 Resize page Method #1
4:19 Resize page Method #2
4:30 Misaligned pin snap Inkscape “transform” problem, and correction
5:32 Drawing to Fritzing standard
6:20 Pin assignment method #1 - Fzitzing Edit pin assignment
7:33 Pin assignment method #1 - Drawing tip
7:53 Pin assignment method #2,3,4 - Inkscape pin assignment
8:55 Text
9:45 Correcting the text “px” problem in the XML code
10:02 Making non important label text
11:02 Loading the schematic drawing into a part and testing it
11:50 Super fast simple schematic drawing
Making Fritzing Parts Fast 4 - PCB pt1
0:00 Intro
0:41 Fritzing drawing rules - Groups
2:31 Drawing PCB svg - Inkscape setup
3:13 Drawing PCB svg - Shortcut method 1
4:04 Getting connector pin svg from Fritzing
4:27 Modifying connector svg to paste into PCB svg
7:30 Inkscape Transform problem
8:48 Adding connector svg into PCB svg
10:19 Fixing the XML for the svg
11:06 Adding non working support pins
11:36 Checking dimensions using the ruler
11:47 Adding text
13:28 Removing the “px” in the text code
13:43 Adding the PCB to a Fritzing part
Making Fritzing Parts Fast pt5 - PCB pt2
0:00 Intro
0:03 Fast PCB method #2 and #3
0:45 Manual drawing - ring pads
2:26 Custom pads - square pads
3:33 Custom pads - oval pads
3:59 testing custom pads
5:48 Plain drill holes
7:46 SMD pads
11:32 Positioning pads
14:20 Silkscreen extras
14:52 Making Fritzing part
Fritzing Parts Fast pt6 - Connectors, Metadata, Check
0:00 Intro
0:11 Connectors
1:37 Metadata
3:26 Internal connections
3:47 Checking part in Fritzing
4:56 Checking PCB output - simple method
5: 45 Checking PCB output - Gerber method
6:57 FritzingPartCheck
7:06 Post part on Fritzing forum
7:13 Errors
----------Please don’t post in this topic so I can keep all the videos together----------
Start a new topic if you want to talk about something here.
