# Finding or making new parts
**URL:** <https://forum.fritzing.org/t/finding-or-making-new-parts/19856>\
**Category:** parts help\
**Created:** [July 3, 2023, 5:56pm UTC](https://forum.fritzing.org/t/finding-or-making-new-parts/19856 "2023-07-03T17:56:14Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![foxley33](https://forum.fritzing.org/letter_avatar_proxy/v4/letter/f/6bbea6/32.png) [@foxley33](https://forum.fritzing.org/u/foxley33)\
**Post date:** [July 3, 2023, 5:56pm UTC](https://forum.fritzing.org/t/finding-or-making-new-parts/19856/1 "2023-07-03T17:56:14Z")
</div>
Hi all, I downloaded Fritzing a couple of days ago having looked around and decided to use Fritzing. My main reason currently is to layout circuits on Vero(strip)board. I have been doing it professionally for nigh on 50 years, but always ‘on the fly’. Some boards have been quite complicated. Anyway, I am trying to be a bit more ‘professional’ ! However I am really having a hard time to get a vertically mounted tantalum bead capacitor with 0.2" pin spacing. Which how almost all of them are made. I have found a 0.1" spaced one and ‘somehow’ got it into the parts bin. But, it is not the one I require. I thought I could generate one as I have CorelDraw and could make an svg file but that failed to work. So, my question is has anyone got one, and even better could someone tell me - simply - how to generate one? Many thanks Roy. p.s. sorry its so long.
**Author:** ![vanepp](https://forum.fritzing.org/user_avatar/forum.fritzing.org/vanepp/32/4426_2.png) [@vanepp](https://forum.fritzing.org/u/vanepp)\
**Post date:** [July 3, 2023, 6:29pm UTC](https://forum.fritzing.org/t/finding-or-making-new-parts/19856/2 "2023-07-03T18:29:50Z")
</div>
While making parts is fairly complex, these two tutorials apply to current versions of Fritzing:
> [@Fritzing PART CREATION Video Tutorial Series](http://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647):
> NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-[Fritzing Parts Fast](https://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647/19) ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-[Fritzing Adv Tips & Tricks](https://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647/15) A series of part creation videos - I’m not an expert, but there was nothing else around at the time. Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -. Recorded slowly for older people, so select a higher speed if it’s too slow. P.S. - Sorry about the voice/sound yum Fritzing Part Creation - Chapter1 - New Part …
> [@Part creation howto part 1 breadboard and pcb](https://forum.fritzing.org/t/part-creation-howto-part-1-breadboard-and-pcb/7692):
> Someone in this forum post requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
that said you are looking for top view parts (which are optimized for perfboard.) I have made some and Blue has made more. A search for top view in the forum should turn up all there are.
