Hello. I’d like to ask why does the ESP-01S need to be connected to the adapter one by one manually? And why, when I put them together, the ESP-01S always stays below the adapter instead of floating above it? Thank you so much for helping me correct the mistakes!
Oh, I’ve solved it. Thank you so much! Really! Thank you!
Other users may one the separate parts
You welcome. Don’t hesitate to ask anything.
Hello. I’m sorry. I’ve found that two small components, C1 and C2, are also needed on the adapter. I’m really sorry about that! I’ve solved the problem regarding the floating issue by myself. Thank you!
Also a trivial change. The connectors and the main graphics just need to be there.
Thank you!!!
