# Elegoo 2.8" Touch TFT
**URL:** <https://forum.fritzing.org/t/elegoo-2-8-touch-tft/7005>\
**Category:** parts help\
**Created:** [April 7, 2019, 1:45pm UTC](https://forum.fritzing.org/t/elegoo-2-8-touch-tft/7005 "2019-04-07T13:45:01Z")\
**Showing post:** 6
**Post date:** [April 7, 2019, 3:44pm UTC](https://forum.fritzing.org/t/elegoo-2-8-touch-tft/7005/6 "2019-04-07T15:44:18Z")
There are a number of problems. Parts editor hasn’t been finished (and at present development has died). Most of the tutorials are for pre parts editor versions of Fritzting, these two apply to the current version (although mine is getting old now), Old\_Grey’s series of videos are probably your best bet (actually asking for help here is your best bet 🙂 ).
> [@A new part creation HowTo (long! So long it is in 2 posts)](http://forum.fritzing.org/t/a-new-part-creation-howto-long-so-long-it-is-in-2-posts/2238):
> (Edit: November 2016: This is an updated (and corrected) version of the original parts creation howto. This version corrects some suggestions (mostly saving Inkscape files as optimized svg which turns out to cause other problems) with the first version and expands the section on parts testing. While there doesn’t appear to be a lot of interest in this subject I’ll make at least this update so the information is as correct as I can get it.) This is a description of how I made the Valor PM6078-00…
> [@Fritzing PART CREATION Video Tutorial Series](http://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647/3):
> Fritzing Part Creation - Chapter3 - Inkscape Advanced Essentials Learning how to draw in Inkscape - more features. 0:00 Overview 0:16 Select object with cursor and XML Editor 3:34 Manipulate special PDF’s in Inkscape 4:33 XML Editor - Direct drawing manipulation 6:05 XML Editor - Making group, moving object, changing layer height 7:27 Cursor - Changing layer height 8:21 Ruler 9:07 Grids 9:28 Snap selection 10:16 Drawing origin
I’ll have a look at the part, the first thing that I see is your svg appears backwards (i.e. bottom looking up rather than top looking down) but I’ll look over the part and see.
_[View the full topic](https://forum.fritzing.org/t/elegoo-2-8-touch-tft/7005)._
