# Does someone has the MAX471 current sensor module Fritzing Part?
**URL:** <https://forum.fritzing.org/t/does-someone-has-the-max471-current-sensor-module-fritzing-part/7946>\
**Category:** uncategorized\
**Created:** [December 20, 2019, 4:09am UTC](https://forum.fritzing.org/t/does-someone-has-the-max471-current-sensor-module-fritzing-part/7946 "2019-12-20T04:09:40Z")\
**Showing post:** 6
**Post date:** [December 20, 2019, 6:18pm UTC](https://forum.fritzing.org/t/does-someone-has-the-max471-current-sensor-module-fritzing-part/7946/6 "2019-12-20T18:18:41Z")
Parts making isn’t easy, but is possible if complex. These tutorials apply to the current version (most of the rest are for earlier versions of the code):
> [@A new part creation HowTo (long! So long it is in 2 posts)](http://forum.fritzing.org/t/a-new-part-creation-howto-long-so-long-it-is-in-2-posts/2238):
> (Edit: November 2016: This is an updated (and corrected) version of the original parts creation howto. This version corrects some suggestions (mostly saving Inkscape files as optimized svg which turns out to cause other problems) with the first version and expands the section on parts testing. While there doesn’t appear to be a lot of interest in this subject I’ll make at least this update so the information is as correct as I can get it.) This is a description of how I made the Valor PM6078-00…
> [@Fritzing PART CREATION Video Tutorial Series](http://forum.fritzing.org/t/fritzing-part-creation-video-tutorial-series/2647/3):
> Fritzing Part Creation - Chapter3 - Inkscape Advanced Essentials Learning how to draw in Inkscape - more features. 0:00 Overview 0:16 Select object with cursor and XML Editor 3:34 Manipulate special PDF’s in Inkscape 4:33 XML Editor - Direct drawing manipulation 6:05 XML Editor - Making group, moving object, changing layer height 7:27 Cursor - Changing layer height 8:21 Ruler 9:07 Grids 9:28 Snap selection 10:16 Drawing origin
if you only need a couple of parts it likely better to ask, and we are always willing to help you make parts.
_[View the full topic](https://forum.fritzing.org/t/does-someone-has-the-max471-current-sensor-module-fritzing-part/7946)._
