# Creating ESP32 SIM800 part
**URL:** <https://forum.fritzing.org/t/creating-esp32-sim800-part/7875>\
**Category:** parts help\
**Created:** [December 8, 2019, 1:57pm UTC](https://forum.fritzing.org/t/creating-esp32-sim800-part/7875 "2019-12-08T13:57:30Z")\
**Showing post:** 31
**Post date:** [December 30, 2021, 2:23am UTC](https://forum.fritzing.org/t/creating-esp32-sim800-part/7875/31 "2021-12-30T02:23:53Z")
By and large fine, a few problems though. Breadboard and schematic are missing layerIds (the only thing that does is make the part not export as an image) and the bus pins are incorrect.
 ![capture](https://forum.fritzing.org/uploads/default/original/2X/9/9ee1224a3e6204d6b2919f529d924337949df7bc.jpeg)
here just rename the first group breadboard
 ![capture1](https://forum.fritzing.org/uploads/default/original/2X/6/6072b5f7cca916936df03f1978118cdcc7a72245.jpeg)
in schematic do a Edit-\>select all then group to create a group of the whole svg and then name it schematic.
 ![capture2](https://forum.fritzing.org/uploads/default/original/2X/0/0e36e1d32c530da640601098ccc6d60ff0660401.jpeg)
For the buses you need to determine the 3 GND bus pins and set them in to the bus in the .fzp file like this:
<bus id="GND">
  <nodeMember connectorId="connector1"/>
  <nodeMember connectorId="connector14"/>
  <nodeMember connectorId="connector26"/>
</bus>
which adds all the ground pins in to the bus so they all light if you click on any of them (as they are internally connected)
 ![capture3](https://forum.fritzing.org/uploads/default/original/2X/3/371f32c7a068788b654b2226d8fc74fa48aa5219.jpeg)
all changes are in this part. You will need to remove your current part (because I didn’t change moduleIds) then shutdown and restart Fritzing before it will let you load this one.
[TTGO-T-Call-SIM800C-improved.fzpz](https://forum.fritzing.org/uploads/short-url/nY1sxgBhm1HIGgNFdrTKYqc4NfP.fzpz) (53.4 KB)
_[View the full topic](https://forum.fritzing.org/t/creating-esp32-sim800-part/7875)._
