# Connect Solar Panel To Breadboard Arduino
**URL:** <https://forum.fritzing.org/t/connect-solar-panel-to-breadboard-arduino/16498>\
**Category:** projects\
**Created:** [July 2, 2022, 5:44pm UTC](https://forum.fritzing.org/t/connect-solar-panel-to-breadboard-arduino/16498 "2022-07-02T17:44:18Z")\
**Showing post:** 8
**Post date:** [July 5, 2022, 2:22pm UTC](https://forum.fritzing.org/t/connect-solar-panel-to-breadboard-arduino/16498/8 "2022-07-05T14:22:45Z")
> [@EmilM21](#):
> Would it work if I add up a 12v module charger(allows me to stack up batteries) with a 12v solar panel and then use Reo rand to reduce the output to 7v for the arduino ?
Yes, except you need to change the reo rand for a buck regulator (the reo rand will only increase the voltage not reduce it.) These ones are common and have a fritzing part:
> [@Mini-360 DC-DC Buck converter](https://forum.fritzing.org/t/mini-360-dc-dc-buck-converter/3931/4):
> It is reasonably trivial to make a modified part. The existing one matches ones I bought from ebay, and in fact all the ones I looked at after typing a search for “mini 360 dc-dc” on ebay in fact show as being 17x11. If you have a pointer to the one you want I can change it easily enough. I assume you want the wider spacing on the silkscreen on pcb view (as I can’t see it mattering particularly anywhere else)? Peter
_[View the full topic](https://forum.fritzing.org/t/connect-solar-panel-to-breadboard-arduino/16498)._
