# 74HC4066 Analogue Switch
**URL:** <https://forum.fritzing.org/t/74hc4066-analogue-switch/23111>\
**Category:** parts help\
**Created:** [April 7, 2024, 4:57pm UTC](https://forum.fritzing.org/t/74hc4066-analogue-switch/23111 "2024-04-07T16:57:50Z")\
**Showing post:** 2
**Post date:** [April 7, 2024, 5:19pm UTC](https://forum.fritzing.org/t/74hc4066-analogue-switch/23111/2 "2024-04-07T17:19:37Z")
A google search for “fritzing part 4066” turns up this forum post with such a part (the 4066 should be same pinout as the 74hc4066 although you need to check!) In general the google search is the best way to find parts (although quality varies, but NoodleDriver’s are usually good.)
> [@Creating parts with movable schematic elements](https://forum.fritzing.org/t/creating-parts-with-movable-schematic-elements/2121/36):
> [1P4T Switch.fzpz](https://forum.fritzing.org/uploads/default/original/2X/5/5c72582870d5abbdad720f1cced4d4ac0b534eec.fzpz) (5.1 KB) [CA3046.fzpz](https://forum.fritzing.org/uploads/default/original/2X/f/f7c3d76d60f28a731bf0dc745b6e269723df5abb.fzpz) (6.6 KB) [CA3080.fzpz](https://forum.fritzing.org/uploads/default/original/2X/7/75464f4768d512d915ae11f310e295ccb65889d3.fzpz) (5.7 KB) [LT44 Transformer.fzpz](https://forum.fritzing.org/uploads/default/original/2X/2/2c163f011205484703dff3fc92830e179480e0cc.fzpz) (5.7 KB) [MPF102.fzpz](https://forum.fritzing.org/uploads/default/original/2X/9/9244c877b83f2a417ddc81545fb6e7469ad202f2.fzpz) (5.5 KB) [OTA.fzpz](https://forum.fritzing.org/uploads/default/original/2X/d/d4128a7da89c4f84d76eb51511865f8681118876.fzpz) (9.0 KB) [TL072.fzpz](https://forum.fritzing.org/uploads/default/original/2X/8/855a8b395001493c18ee9b8173357bcef8f8b50e.fzpz) (13.3 KB) [CD4066.fzpz](https://forum.fritzing.org/uploads/default/original/2X/1/196219972183d6b32b9ef4d3101ea3c7972efe57.fzpz) (198.8 KB) [TL074 Quad Opamp (Movable).fzpz](https://forum.fritzing.org/uploads/default/original/2X/1/1f1b4fd29285fb9d53a2a997e6c145f773f546a4.fzpz) (8.9 KB) Some of these are slightly messy looking but they all work! I have tested all\* of these on my own PCB projects… \*I have not tested the 3080 yet TBH but it looks perfect. edit: The 3080 works like a charm smiley More parts to follow below…
_[View the full topic](https://forum.fritzing.org/t/74hc4066-analogue-switch/23111)._
