PM6078-004 5 Volt to 9 Volt DC-DC converter by Valor
Obsolete for many years, but available surplus cheap ($.30 US at present) from
http://www.bgmicro.com/pm6078-004.aspx
Views created: breadboard / schematic / pcb
Views tested: breadboard / schematic / pcb
In the form of drag the part in along with 4 1 pin connectors, and connect a connector to each of the 4 active pins. Make sure the part aligns correctly on the grid and the connections all work in all views and the connector numbers match to the same pins in all 3 views. Have not yet used it to produce a board though.
(Edit 26Oct2016)
Turns out the footprint on this part (and all the parts I have done so far!) is incorrect. So I am replacing the original file with a corrected one that has a better (but still not tested by cutting a PCB) version of the footprint. If you have downloaded this part you should replace it with this update.
Valor_pm6078_004_dip24_600mil_1.fzpz (8.4 KB)
Peter Van Epp
