TXS0108EPW Logic Level Converter
This 8-bit non-inverting translator uses two separate
configurable power-supply rails. The A port tracks the
VCCA pin supply voltage. The VCCA pin accepts any
supply voltage between 1.2 V and 3.6 V. The B port
tracks the VCCB pin supply voltage. The VCCB pin
accepts any supply voltage between 1.65 V and 5.5
V. Two input supply pins allows for low Voltage
bidirectional translation between any of the 1.2 V, 1.8
V, 2.5 V, 3.3 V, and 5 V voltage nodes.
TXS0108.fzpz (8.1 KB)
Shift level converter wie kann ich den
