There is no FC-51 IR obstacle sensor?
How could it happen that I can not find the FC-51 IR obstacle sensor in the library?
If you are still interested, I just posted a part for this in parts_submit.
I genuinely have to ask why one would need this in the library. If I was making a PCB that needed this attached to it I would use a simple 3 pin header. Am I missing something here?
Spoken like someone who uses fritzing only for pcb’s :slight_smile: , I usually use it for breadboard view for documenting projects on perf board and documenting the connecting together of modules like this one. So in this case it is breadboard and schematic views that are valuable to some of us.
