Stripboard / Veroboard does not work properly. :(
Extended stripboard beyond the default value. The extended area is created as all tracks connected matrix, not strips.
Stripboard with strips appearing to extended area
Win 10 64 bit, 0.9.3b
It helps to do a search for your problem before posting. All it took was a search for the word stripboard in the forum and the first result was Stripboard / Veroboard extension not working correctly and it has almost exactly the same title as yours so it is likely the forum suggested it as an answer when you started to type in your title.
