Dear all, this is my first post here, and I’m a newb Fritzing user altogether. I find it a fantastic app with great community support, hence I want to dive deeper.
For my project, I am going to use Si7021-based sensor breakout boards I bought from China. They are described in detail on MySensors: https://www.mysensors.org/build/humidity_si7021. Unfortunately, I haven’t found this specific board part for Fritzing yet.
So the question is how should I search for it, to make sure I don’t start learning new part design instead of reusing something already made.
A google search for “fritzing part si7021” turns up parts in both adafruit’s and sparkfun’s frtizing repos as well as this project on the Fritzing projects site which has a part in the temp part bin:
Correct, found all of those, they are all not what I am looking for (unless I am blind).
The part I am after looks very much like the barometric pressure sensor GY-68 from the project you linked as well as the VERTER buck-boost there. So much so that I was thinking of re-using those to create the part myself (but it’s still a major effort for me to do it right). It does not look like the Adafruit or the SparkFun modules.
Potentially, the part may also be called SHT21 (see the page I linked in the original post), and I now even found a page showing a Fritzing layout with those modules: https://alxhou.wordpress.com/2012/07/01/multiple-sht21-softi2c/. But as you can see, the part is not drawn according to Fritzing quality, and I cannot download it anyway (could contact the guy of course if I cannot find the solution otherwise).
I was looking at the SI7021 part, but you are correct the pinout is different (perhaps sparkfun’s version). When I get some time I’ll change it in to a correct (or at least correcter) part.
