Several 74HCxx parts
I’m a homeschool parent and as part of the electronics class I have been teaching we have been using Fritzing for the design part of the class. We recently completed a section on boolean operations using several of the 74xx logic gate ICs. While I am new to both the Fritzing application and creating new parts I thought I would share the parts that I created. Please advise if these parts were created improperly.
Per forum requirements each part is in a separate topic.
Thanks,
Doug
74xx Parts
  • 74HC00
  • 74HC04
  • 74HC08
  • 74HC11
  • 74HC14
  • 74HC30
  • 74HC32
  • 74HC86
  • 74HC4002
  • 74HC4075
  • 74HC4078
  • 74HC7266
    Other
  • MC14490P
  • 7555
I just installed fritzing. I’m interested about using 74xx parts. I did not understand how to contact you. Did you create only logic gate or also flip flop?
Thank you.
Bye,
Salvatore
Can you share it?
A google search of the form “frtizing part 74hc00” (or 7400) will turn up parts available on the net. If there aren’t any available (which willl sometimes be the case) then the part can be created from the generic IC part or if you need the logic symbol (rather than a box with the pin names) by making a custom part (which is a fair bit harder than using the generic IC.)
