Is it possible to set default wire thickness to “thick”? If not is it possible to add this option in future releases? It is important that the the lines are thick for hand-made PCBs.
If you are talking about PCB trace thickness, you just punch the number into the Inspector.
Assuming you are talking about changing default behavior which currently defaults to standard (24mil), it is on my list (because it annoys me to have to click to reset it to something larger or smaller. If we manage to get development going again which unfortunately is a big if.
Yes exactly, in the event that I have to hand make my PCB again I have to go through and change all pcb thickness’ everytime i draw a trace
You can go Routing/select all traces, and then change them as a group. If you have a few individuals you can change them after.
