ROHM BU4SU69G2 Single Inverter in SSOP-5 case
Here is a new part and footprint for the BU4SU69G2 from Rohm with a SSOP-5 case.
Not verified yet.
BU4SU69G2.fzpz (7.1 KB)
Not bad, the main visible problem is schematic isn’t aligned to the .1 grid. That was probably caused by not doing a resize page to selection (after edit->select all, and assuming Inkscape). There are a number of other issues which I fixed up as well in this improved version of your part:
BU4SU69G2-improved.fzpz (7.5 KB)
(I didn’t change moduleIds so you need to delete you old part to load this one).
Thank you a lot for improvement. This are my first parts I create and still learning how to do it in Fritzing.
#4
You are most welcome. Unfortunately much of the documentation on parts making that is out there is for older versions of Fritzing so the details of parts making are mostly being passed along here in the forums. Development on Fritzing is restarting (after a couple of years of nothing) so hopefully things may improve in future. If you have questions, feel free to ask, the more people making parts the better.
