Request - PC123 SHARP
I need your help! I need a lot to use a component that I did not find in Fritzing, this component is the Optocoupler PC123 SHARP. I do not have the necessary skills to create the componete and I do not know how to do it correctly. Can anybody help me? The specifications are as follows:
https://www.tme.eu/en/Document/696e74da6e27c6e71ee8567df0dbbd47/PC123FY2.pdf
http://www.datasheetcatalog.com/datasheets_pdf/P/C/1/2/PC123.shtml
From the datasheet the sharp pc817 in core parts is identical. You can use that and edit the part number with parts editor if you want.
