Relays and wires
1.That would be great if you had an option to add more switch inside de relay, this version only have one.
2.In past versions we could drag the components and the wires stay with it to anywhere you move the component.
As for issue number one… I couldn’t find much in the options for relays either… I may need to add that to my to-do list…
As for issue number two; when you place a part on the breadboard and connect a wire to the component, the wire will take precedence to the breadboard socket (female pin). If you want the wire to stay with the component while dragging it around… take the component off of the breadboard, then connect the wire to it. You can then drag the component on to the breadboard or anywhere you want and the wire will stay with it.
