No encuentro el grafico de cinta led
en donde encuentro la cinta led
Assuming you are looking for neopixel like devices a google search on “fritzing part led 5050” turns up a number of hits.
http://fritzing.org/projects/rgb-strip-led-smd-5050
is one there also appear to be several in the adafruit fritzing library on github which isn’t loaded by default (so you would need to load it for yourself).
