Hello, need help to increase spacing on part. Example on resistor. I edited it in Inkscape, looks good, but when I use the part on the PCB screen RED dot does not show up in the proper spot. How do I correct that?
You have artifacts in the svg drawing that the pins are still assigned to.
Reassign the pins in FZ editor.
You also could remove the rubbish in the svg if you want it neater.
in the Inspector you can select different THT pin spacing in the pin spacing drop-down list.
Thank you for your help
