Mini JST XH2.54mm 4Pin Connector
Does anyone know if this part is already in the library, and if so whats it under. Ive done a search but can’t find it
Ebay link
Thanks
Brian
I don’t think we have exactly these, but the molex should be close enough. Drag a connector out of core parts in to the sketch then right click it and in Inspector (bottom right window) click on the form pull down menu and select molex. That gives a shrouded connector in pcb that should be fairly close. Setting the pins pull down to 4 will expand it to 4 position.
Great, thanks :slight_smile:
Need Some Custom Parts Made
