Light Dependant Resistor 100 mil THT
The one in Fritzing had the wrong PCB footprint.
0.100" THT footprint.
v1 - LDR - Photocell (LDR).fzpz (9.4 KB)
EDIT
I changed the pad sizes and changed the silkscreen.
EDIT EDIT
I changed the silkscreen size in PCB, as it’s a touch wider than the pads.
EDIT EDIT EDIT
It was wrong again. The svg shows the correct 0.100" pin spacing, but when you import it into FZ it becomes bigger.
