Lbr2svg for converting Eagle Part to Fritzing SVG's
Hi…i am a new user here. In my case when I run the command “lbr2svg” and get the error “command not found”. I’m in the following directory ~/eagle-7.6.0/lbr/seeed/lbr2svg. I’ve it with the extension and without, as root and without. The file is in the directory. Any suggestion.
flex pcb assembly
