How do you get a standard resistor to draw as vertical on a breadboard?
When you lay down a standard resistor, it spans 5 holes. If I wanted to stand the resistor vertically to save space, how do I do that?
Or is there another part for a vertical resistor?
http://fritzing.org/about/roadmap/parts-plan/
Says:
resistors being “vertically mounted” - spacing would be 100 or 200 mil, but currently the list only goes down to 300 (we do have a couple in now)
#3
Sorry to be digging up an old thread, but has there been any progress on this?
I too wish to mount resistors on the STRIPBOARD vertically (when going across a TO-92 transistor pins) and the response given only works on the PCB view :frowning:
#4
The std ones only standup in PCB.
I remember someone making a part, but not if it was standing up in BB view. I think it was Vanepp so we will have wait to see what he says.
#5
I had put this on Fz a long time ago but can’t find the thread, so here it is again…
Vertical Resistor.fzpz (4.7 KB)
Mini Resistor Part
#6
Thank you :slight_smile:
Are there any more vertical parts i can download from somewhere?
I tried searching but didn’t have luck finding anything.
#7
I am not aware of any right of the top of my head… Vanepp is more up to date on this stuff, he might know. Anything special you are looking for?
#8
I found this diode… Search around of Fritzing you might find a few more.
#9
I’m also trying to find an RF choke (i suppose i can edit a resistor and give it a different colour to differentiate), ceramic capacitors, and zener diodes. I’m mounting these all vertically and two holes wide.
Building a tiny PCB (no more than 2.5x2.5inch) and need the parts to stay tight. Doing a few test runs via the breadboard to make sure it all works as it should before building the PCB with the same parts.
#10
Sorry Steel, it was you that made that part.
Vanepp linked about 20 upright parts in a post recently, but I can’t find it.
#11
If you search the forum for “top view” there are leds, TO220, ceramic cap and electrolitic caps available for use on perf board in breadboard view but not a lot, not an inductor as far as I know. There may be a small signal diode in upright as well (I made one a long time ago, don’t remember if upright was one of them)).
There are too many words for it, because I tried standup, vertical, upright, and didn’t get much.
