The MAX31855 appears to be in the adafruit fritzing library (which isn’t loaded by default in Fritzing but is available as a bin on github). For the power supply this should do. As always you need to verify the pcb foot print against a real part as I don’t have one.
Hi Peter,
thank you very much for sm-014.fzpz, it helps a lot.
Ad of MAX31855 module, there are more versions on the market. Unfortunately, the basic plate, which contains only MAX31855 (it has only 5 pins, not six), is not included in the adafruit fritzing library.
Doesn’t look easy. There is no mechanical drawing that I can see on the net (not uncommon for these) for the 5 pin version. Without that or an example to measure there isn’t a way to cut down the adafruit part (which would be relatively trivial). Unless you need pcb view (in which case you need the exact dimensions) the adafruit one should serve as it has most of the needed connections (I assume Vin is probably VCC on your module).
