Pancake Inductor.fzpz (15.4 KB)
Fully working etchable pancake coil.
Still needs meta data.
Finally found it, i was searching for this message for a few hours.
So there is no option available like a an id of another tag to define a solder mask in xml?
or a solder mask layer?
Import into Fritzing, edit part and add Meta, and then export and itās finished.
Yea, I hope my calculated induction value is close enough to the real world
Iām still thinking what to do with the solder mask issue. If I send this to a fab house then it would be silly if I have to DIY paint my own solder mask.
And I discovered a few more issues.
There is also no Drill data generated for any of the holes, or at least the drill file file is nearly emptyā¦
And⦠there was another thing⦠canāt remember it right now.
All holes have to be in the copper groups.
Someone also worked out how to change the solder mask.
