ESP8266 Usb adapter (CH340) part needed
This should do what you want. The size probably isn’t correct, because the listed size (4.8*3.5cm) is obviously from the photo incorrect so I made it a bit bigger than the connector. It has no pcb view as it isn’t useful. You should verify the pins are correct before depending on it as there also isn’t much connector information and it may be wrong.
ESP8266 Usb adapter (CH340).fzpz (15.6 KB)
Thanks vanepp.
I need this part only circuit scheme. I can use this.
