Edit specification of multiple components at the same time
If I select multiple resistors at the same time and try to change their value simultaneously, the change doesn’t take effect.
Each resistor is generated independently. The best way to create multiple resistors with the same value, is to create one resistor, set the value, then duplicate that resistor.
To duplicate multiple item at one time, please read this post: Multiple selection of parts
