NSL - 3SR3 Optocoupler.fzpz (4.8 KB)
V23079 - 2 Coil 5V Latching Relay (without breadboard view or icons)
V23079 - @ RS
Latching Relay.fzpz (6.1 KB)
It turns out that the TL074 part above has a number of problems, the most serious being it only has copper0 defined for pcb in the fzp file (although it is a through hole part.) Someone ran in to this and reported it as a problem on github and I corrected the part for them in this corrected part:
TL074-Quad-Opamp-(Movable)-improved.fzpz (7.2 KB)
So if you need one of these use this one …
Cheers Peter.
I made some better versions of this and others listed above which I’ll upload as soon as I get a chance. This was made when I was finding my feet with Fritzing and Illustrator.
Thanks for fixing this one
You and me both! FritzingCheckPart hadn’t been written yet at that point, and all of us were trying to figure out how subparts worked. These days FritzingCheckPart will check subparts for correctness (with some limitations.)
