Can't change LED after initial Inspector selection
I pulled a std 5mm LED from the CORE part bin and put it in Breadboard view.
I then switched it to 3mm.
Then I selected something else, so it wasn’t highlighted by the box - I clicked anywhere on the sketch -.
I then selected it again, so it was highlighted by the box, and chose 5mm again, and it turns into a clear multi colour LED with no way to get it back to a std LED any more.
I was expecting the Inspector to be able to switch it to a different size when re selected.
V 0.9.2
Win 7 64
This one is still kind-of there. You can switch a 5mm LED to 3mm, but you can’t change it back to 5mm as it always defaults to RGBB 6 legged LED. It would be good to be able to switch between the two quickly rather than deleting the part and rewiring another new correct one in because it’s pretty common to change LED sizes in PCB depending in space availability.
Sorry dudes. lol
