Can't bring holes or vias to front on single sided PCB
You can’t put a hole or via ON a track with the front and back options on a single sides PCB, so that they aren’t hidden by the track.
Start new and go to PCB.
Changed PCB to single sided
Put 2 headers on a PCB.
Link wire between both.
Changed wire to 70mil and moved it back.
Add hole and move to front.
Moved hole over track and it goes behind the track.
I would like to see where holes and vias are.
Win7 64 SP1
v0.9.3
