Unfortunatly no (AFAIK), the parts that change in inspector are two different parts with magic in the fzp file to tap in to code in the core bins to change attributes (and then only some attributes). You would need to make two different parts one with each schematic and then if there is a suitable attribute we can tell you how to modify the fzp file to make core think your part is blessed and let inspector change the attributes.
