C# to Arduino Design and Code
I have a fast project for school to create a controller for showers.
I have written the code in C# and i would appreciate if anyone can convert it to arduino code, and design it in breadboard.
Kind Regards
public partial class Form1 : Form
int OrigTime1 = 360;
int OrigTime2 = 360;
bool Shower1 = false;
bool Shower1ON = false;
bool Shower2 = false;
bool Shower2ON = false;
private DateTime startTime;
    public Form1()
        InitializeComponent();
    private void btnStart1_Click(object sender, EventArgs e)
        btnLed1.BackColor = Color.Red;
        timer1.Start();
        startTime = DateTime.Now;
    private void btnStart2_Click(object sender, EventArgs e)
        btnLed2.BackColor = Color.Red;
        timer2.Start(); // start timer (you can do it on form load, if you need)
        startTime = DateTime.Now; // and remember start time
    private void timer1_Tick(object sender, EventArgs e)
        Shower1 = true;
        OrigTime1--;
        lblTimer1.Text = OrigTime1 / 60 + ":" + ((OrigTime1 % 60) >= 10 ? (OrigTime1 % 60).ToString() : "0" + OrigTime1 % 60);
        int elapsedSeconds = (int)(DateTime.Now - startTime).TotalSeconds;
        int remainingSeconds = OrigTime1 - elapsedSeconds;
        if (remainingSeconds <= 0)
            btnLed1.BackColor = Color.Green;
            lblTimer1.Text = "00:00";  //no need for display
            timer1.Stop();
            btnShowerLed1.BackColor = Color.Green;
            OrigTime1 = 360;  //reset timer
            Shower1 = false;  //disable the shower
    private void timer2_Tick(object sender, EventArgs e)
        Shower2 = true;
        OrigTime2--;
        lblTimer2.Text = OrigTime2 / 60 + ":" + ((OrigTime2 % 60) >= 10 ? (OrigTime2 % 60).ToString() : "0" + OrigTime2 % 60);
        int remainingSeconds = OrigTime2 - elapsedSeconds;
            btnLed2.BackColor = Color.Green;
            lblTimer2.Text = "00:00";  //no need for display
            timer2.Stop();
            btnShowerLed2.BackColor = Color.Green;
            OrigTime2 = 360;  //reset timer
            Shower2 = false;  //disable the shower
    private void btnShower1_Click(object sender, EventArgs e)
        if (Shower1)  //check if shower is enabled
            if (!Shower1ON)  //check if shower in on (running water)
                btnShowerLed1.BackColor = Color.Red;  //shower on (water on)
                Shower1ON = true;
            else if (Shower1ON)
                btnShowerLed1.BackColor = Color.Orange;  //stand by (water stoped)
                Shower1ON = false;
        else
    private void btnShower2_Click(object sender, EventArgs e)
        if (Shower2)  //check if shower is enabled
            if (!Shower2ON) //check if shower in on (running water)
                btnShowerLed2.BackColor = Color.Red;  //shower on (water on)
                Shower2ON = true;
            else if (Shower2ON)
                btnShowerLed2.BackColor = Color.Orange;  //stand by (water stoped)
                Shower2ON = false;
        else
