When you Copy Paste, the Paste pastes on the centre of the screen with each additional one being pasted on a diagonal moving down until it goes off the screen. This is annoying because you have to zoom out and in all the time.
Can the Paste paste only on the current view screen.
I agree, paste at mouse pointer position would be more logical. Also if you copy a selection of objects it tricky NOT to past it on top of anything else.
What I was doing when I knew the next part was going to be off screen, I pressed Copy, because the same last part is still selected, so that when it pastes the current copy it does it back in the middle of the screen. Not efficient because you have to press Copy again, but better than going off screen.
