Arduino CNC with Fritzing PCB, GNU Image Manipulation Program - GIMP, Inkscape (with GCodetools) and bCNC
Attached .pdf with instructing sequence of images getting graphic for Arduino (with GBRL) CNC from .jpg image of the PCB generated in Fritzing, then edited in GNU Image Manipulation Program - GIMP, after Gcode .ngc generated in Inkscape (with Gcodetools plugin) and finally import for bCNC.
Fritzing_image_PCB_for_CNC.pdf
