Api-ms-win-crt-runtime-l1-1-0.dll Fix?
#21
In response to "sublimeartistry"
Not all of us are programmers and if we could correct the problems we would have done it already.
I got the impression from previous posts that is was only a missing dll. Some even suggested download links.
This is why I was wondering why you do not add it.
However, even though I downloaded and installed it (not only the dll but the complete distributable) but still it is not working, so this means that it is not as simple as this.
All in all, I have the feeling that many people are affected by this and i anyone could help it would be great to do so.
Sorry if i offended someone. Didn’t mean to do so!
#22
The runtime download is certainly a requirement, that doesn’t mean that more things can go wrong though. What isn’t working now? The most common problem after the runtime dll is not waiting for the parts update to finish and/or closing the program before it finishes (a progress bar for that download is one of the projects on my list of things to fix). It that happens you need to delete the user directories to clear the corruption. There are a number of posts on how to do that or I can provide instructions.
If the runtime is a requirement, please provide a link or instructions to find the correct version.
I already downloaded one from somewhere, installed it, rebooted and still the same problem and the same message.
#24
I think (because I’ve always had multiple copies of the C runtimes on my machine and thus never seen the problem) that any recent copy of the runtime libs should work. There are a couple of links back in this thread and even more if you type dll in to the forum search bar.
Exactly those links I used (f.e. https://www.smartftp.com/support/kb/the-program-cant-start-because-api-ms-win-crt-runtime-l1-1-0dll-is-missing-f2702.html ) but still no solution to the problem.
#26
OK lets try something different. On my Win 7 pro box in
Control Panel\Programs\Programs and Features
I have
Microsoft Visual C++ 2013 Redistributable (x64)-12.0.21005
Microsoft Visual C++ 2015 Redistributable (x64)-14.0.24215
and I believe it is using one or the other of those (in theory the 2015 one I think). One or the other of these was supposed to be loaded (and was in my case) by Windows Update. There were however problems and many systems didn’t get the update. If you don’t have one or the other of those showing in the programs window, I’d suggest checking if Windows update is running correctly (one of the patches broke it back in November on this system and I had to delete the update directory to make update work again). An easy test for that is open Windows Update from the start menu and try and check for updates. If it says it can’t then you likely have the bad patch and need to fix it to get updates again. You may also try downloading the libraries from Microsoft.
I used “win 7 download the c run time libraries” (because I have Win7) and the first couple of hits are Microsoft who is the official source of the libraries. I believe they vary by Windows version as well so substitute your version of Windows in there (which is why we can say one download fixes all, because it doesn’t). Windows 10 when it first came out had a lot of troubles with this, but I haven’t seen a lot of complaints lately.
This is what I have installed…
I guess the last one (which was installed on 27/01/2018) is the one I installed cause of Fritzing…
As far as I know it is the latest version which I downloaded from Microsoft.
#28
With this you still get the missing dll error? If so that would indicate you either need the 2015 version for some reason, although from what I have read the 2017 version is supposed to be compatible or it isn’t complaining about the run time library. Can you post the exact error message you are getting with the dll name it is missing please? Its possible that it isn’t complaining about the runtime libaries but something else and we are chasing the wrong problem here.
Here it is… I reproduced the error on top of our messages to see it is not something old…
#30
Well this is a new one. Unfortunatly I don’t have an answer. I just built a development disk with Qt and Visual Studio which is using the 2017 Redistibutable. I just deleted the 2005 and 2013 versions to make sure it wasn’t using one of those, and Fritzing still starts fine for me using the 2017 Redistributables. You might try deleting all the Fritzing files (assuming you don’t have any sketches or parts that you want to keep) and see if a reinstall helps. As well as the files that loaded from the zip file there are two user directories that don’t get updated if the program is reinstalled (although that doesn’t usually cause this particular problem):
There are two user directories (with your parts and the parts database) which don’t get touched during an install (to not affect your sketchs during upgrades). On Windows they are in
If you don’t have any parts or sketches you want to keep you can just delete those two directories and Fritzing will recreate them, or you can move them aside by renaming them if you wan to keep something in them.
If that works, the first launch of Fritzing will appear to hang (as it updates the parts database from github). Just wait until it completes, it will eventually tell you there are new parts available, as interrupting it is what causes you to need to delete the two files above usually.
A new one? But -I guess- it is exactly the same problems that others were having in the beginning of this discussion, and this is why I posted here!
I do not see any difference… Please have a look at the title of the discussion:
“Api-ms-win-crt-runtime-l1-1-0.dll Fix?”
I have already reinstalled the program without any success.
There is no problem with lode files since I have NEVER used it (in this computer) simply cause it never run!
I guess there is no hope…
:frowning:
#32
It is a new one in that loading the runtime libs hasn’t fixed the problem. In all previous cases I know of (unless some people just gave up, which is possible) loading the runtime libraries has fixed this issue. With Windows 10 that often took a number of tries to get it right back in the days of one of the early patches, but eventually it fixed it. As I said I don’t have any more suggestions, it runs on lots of Windows machines (I have 5 of various flavors) on any of the supported OSes (I don’t believe it will run on XP because of runtime library issues but I haven’t tried either). Something appears to be odd about your machine is about as much as I can say.
