Add text and boxes to schematic view
I want to be able to add text and boxes to the schematic view. Someone asked for this years ago also. Thanks.
The edit->add note function may do what you want. Otherwise you would have to either create the function in the source or find someone to do it …
There are several ways to add text and descriptions in the schematic view.
Exported as SVG:
textbox
If those are not sufficient, or have any issues, then it would help a lot
to describe (maybe even with a free hand drawing) how it should work or look.
For example:
  • When using rich text to set a white background in a note, then the SVG export does not render the white background.
  • How can I enter rich text into a note
    (answer: copy and paste styled text, for example from a rich text editor or from a browser)
The PNG export:
