8 channels level logic converter
Hello.
I’ve just started to made simple sketch form my arduino project but I couldn’t find any project about this part: https://www.waveshare.com/logic-level-converter.htm .
I can’t develop any new part in fritzing so mayby anyone of you could made this part and share?
I’ll be very gratefull for any help.
This should do the job. Note there is no pcb as there isn’t any connection on pcb possible.
Edit: replace part to add pin labels in breadboard and correct connections on Bside. If you downloaded the original version replace it with this one.
Waveshare 8 channel logic level converter.fzpz (24.5 KB)
Thanks a lot, but is it possible to make it with visible pins labels?
Sure, I have replaced the original part with one with pin labels in breadboard and correct pinout on the B side.
