Hi Guys
Thanks for your replies, sorry for my delay in getting back to you. As with most apps when you first start using them it’s a up steep learning curve, I’m slowly getting my head round it. I find knowing the right question means you will get the right answer, the problem is knowing the right questions to ask !
Old_Grey
Thanks for the links, the biggest issue I hit was all the information I could find were using Inkscape, I use Coreldraw so it took a lot of digging until I found what I was looking for. The 2 main bits of information I need were the colours to use, and the ID tags (also in Coreldraw what grouping I needed to get the correct output). Its also not helped, and this a internet common problem when links are out of date, “for further info click here” which take you to the wrong page LOL
Vanepp (Peter)
Thanks for the part, I did load it but the size wasn’t correct when laying it out in the PCB view. Based on digging, Old_Grey 's videos, and the part you made I have made my own, I think its working, graphics may not be as nice as yours but the size was the most important part (no jokes please LOL)
Here is what I came up with, I think is working, if you wouldn’t mind checking it that would be great, that way I will know if I have understood this correctly.
Parallel 18650 battery.fzpz (12.9 KB)
I have hit one problem, I’m doing a custom board design, in PCB viewer it looks OK, but when I upload it to the aisler.net one of the hole was missing. Having read what I could find on custom boards, when you make a board you must “merged shape with no stroke”, the only way I can get it to work is a group of 4 objects (the 4 hols and the board) with a white stroke
Thanks for your help
Brian
