174917_DENSO-ECU-socket_48pin-040-070 - Mazda Miata MX5 old 48pin ECU socket -
UPDATED 2Nov16
V2.0 174917_DENSO-ECU-socket_48pin-040-070.fzpz (27.1 KB)
Visible changes :-
1-Mounting feet added to silkscreen so as to allow positioning of 3-4mm high components in the gap under the socket.
2-Mounting holes changed from 4mm to 3.5mm, as per drawing, to increase sheer strength of socket due to less play in holes.
3-PCB svg totally redone for more accuracy. Basically the silkscreen is a touch smaller due to now being 1:1.
Non-Visible changes :-
The whole part was totally redone from scratch in all views and XML file, so as to make it tidy and more accurate.
How to change part in old sketches without loosing connections.
Import part into MINE bin.
Click on new part and note variant #.
Click on old part in sketch and select new variant in Inspector.
