16x2 I2C LCD Part
Very new to Fritzing so be gentle.
I’ve had a look about and either I’ve lost the plot and its staring me in the face or its not in the standard parts bin. But, is there a 16x2 LCD that is I2C rather than the wirefest that is the standard 16x2 LCD? Or do I need to create a part / use an I2C module
Thanks
Alex
googleing for Fritzing 1602 lcd i2c part (or ritzing 1602 lcd i2c part as I actually did :slight_smile: ) turns up:
http://fritzing.org/projects/lcd-i2c-analog-inputoutput-displayed
which from only a look at the description appears to include one of the i2c converter boards.
Peter Van Epp
#3
That’s the one I found too Peter. I think I’ll make life easier and leave a header on the board rather than trying to wire it all in until I can work out how to produce a proper part.
Thanks
Alex
#4
I’m struggling with the create a part issue right now (or more correctly will be again once I finish a different task) so perhaps I’ll have some pointers, as it isn’t at all easy and all the docs I’ve found are not very good (they tend to leave out a lot of vital details).
Peter Van Epp
#5
@g7kse, Is this what you are looking for? LCD1602-I2C.fzpz (10.2 KB)
#6
Spot on Steelgoose. Thanks very much
Alex
#7
Thanks steelgoose
u are da best
#8
Thank you so much for this. You literally saved me hours worth of work. Great contribution!
